Intermediate certificate chain
Can anyone tell my why free hosting accounts cannot upload the certificate intermediate chain so that SSL testing sites give you a higher benchmark rating for a valid CAA trusted authority chain back to the root certificate? I know for most cases, its not needed, but it would be nice to have.
Is this something that infinity have just decided to make a premium feature, or is there a technical reason?
Intermediates are not supported on Free Hosting. If you want an intermediate, you should consider upgrading to Premium.
It’s just not supported. Admin may know the reason why, but it probably has to do with the fact that iFastNet does not want to support it.
I don’t, really… I was just wondering is all - there’s no technical reason that I could think of. Although if infinity’s host doesn’t allow it, then I can understand how that gets passed down the layers to us poor souls at the bottom :smiley:
If you want more of an intermediate-type certificate, you should consider CloudFlare. If you do, I suggest Full SSL.
