Inodes Cleaning, How Can I meak a Cron to Cleaning or delet Inodes automaticly ?
Inodes Cleaning,
Inodes are the number of files and directories in your account. So to reduce the inode counter of your account, you will need to delete some files and directories.
What is the best way for you to reduce your inode counter depends on why you have so many files. You could delete some unused stuff, split separate websites to separate accounts (you’re allowed to have up to 3 accounts) or have a script which deletes some old temporary files (and run that through cron). But again, it all depends on the contents of your account.
