Inode problem
I found my inodes excess limit and I tried to delet most of my files. From the knowledgebase, website will be refresh after 8 hours. But it did not happen, please help. Thanks.
No info = no help
My advice? Wait…
How many inodes to have for the two upgrade plan? There are PHP8.2?
You tried to delete the files, or you did delete the files? You have to actually remove about 1,000 to 5,000 files / folders.
I checked your account, and the htdocs/edu folder still has a very large number of files. So as far as I can tell, the inode counters and limits are all working as they are supposed to.
No hard limits have been set as far as I know, but it’s in the ballpark of 400,000.
Yes. You can choose any PHP version from 4.4 up to the latest version.
