Inode limit in premium plans
Hi! There’s a limit of inodes in free plan. Does it limit will be in premium plan & if yes, what’s size it will be?
I’m planing to upgrade cause need more files limit but can’t find info about this.
Thanx.
Thanx.
I am glad to hear you are considering on upgrading to premium! :slight_smile:
Nope, there is no innode limit on premium plans! All premium plans don’t have innode limit.
I don’t think there is any limit, but you should really ask such questions to the company which provides the premium hosting.
Hi, In some companies, Inode limit does exsist but it’s higher than free one’s. I had mine at 200.000 limit. This of course depends on the company and the plan. VPS and Dedicated server’s usually does not limit Inode and most Premium Shared Hosting does.
