Index3.html
I have a rule that directs access to non-exist files to the root.
I don’t have index3.html on the server.
RewriteEngine on
RewriteRule . / [L,R=301]
The behavior to access index3.html (non-exist file) is https://errors.infinityfree.net/errors/404/.
This is wrong because the rule says to redirect it to /
All other urls to non-exist files are redirected correctly.
Why is index3.html so special?
Why don’t you just set ErrorDocument:
ErrorDocument 404 /
Yeah, this is simpler.
I think I know my issue.
The rule messed up is probably due to the cache.
I cleared the cache and then the behavior is correct.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
