My best guess the other issues started when you un-comment the other “RewriteEngine On” statement.
Best practice is one “RewriteEngine On” per .htaccess
thanks for your reply and now I am understanding what broke but right now my htaccess file only has 3 lines in it
RewriteEngine On
RewriteRule ^([^.]+)$ $1.html [NC,L]
These 3 above lines are commented and I can access index.html from my sub folder without having to type in index.html into my path. The above code allows one to type in a file without the .html extension but when I uncomment the 3 lines the html extension does not appear as intended but now index.html in sub folder throws a 403 error. So we fixed issue number one but when I use this rewrite directive in issue number 2 then now issue number one is broken again
Ok, so this is what you would follow for that. I am mainly linking this so you can read the text hi-lighted in red.
https://tinkertechlab.com/webhosting/htaccess/remove-file-extensions
Wait, so what is the second issue? As far as I understand it, these are the two things you wanted:
So these should be the ONLY three lines in your htaccess file:
RewriteEngine on
Thanks so much for your patience!! Yes these are the 2 issues, You have it correct, so the following needs to work (both at the same time, not one or the other)
https://cookiefreecoders.com/Java/
and
https://cookiefreecoders.com/Java/JDBC where JDBC is a file with no html extension
I did as u suggested in htaccess, and cleared my cache
the following now happens
https://cookiefreecoders.com/JDBC …this pulls up the JDBC file with no extension
https://cookiefreecoders.com/Java/JDBC …this also works with no extension
https://cookiefreecoders.com/Java/ …now shows 403 error and i need it to default to the index.html page
so now when we fix issue 2 then issue 1 is broken again. Maybe the trailing slash has something to do with it
maybe we also need
RewriteCond %{REQUEST_FILENAME} !-d in addition to !-f
because we are dealing with both directory and file, just guessing
maybe it now thinks /Java/ is a file instead of a directory so it forbids access
also maybe we need a .* in the rule but am very confused at the moment
with no rewrite rule issue number 1 does work
PS: trailing slash means it is a directory and no trailing slash means it is a file
Ok, can you share the contents of the following three htaccess files? If they don’t exist, just say that, no need to create it.
1
# DO NOT EDIT THIS FILE
# Create a new .htaccess file in your htdocs
# directory (or example.com/htdocs/ directory)
# to add your own rules or override these rules.
DirectoryIndex index.php index.html index.htm index2.html
ErrorDocument 403 https://errors.infinityfree.net/errors/403/
ErrorDocument 404 https://errors.infinityfree.net/errors/404/
ErrorDocument 500 https://errors.infinityfree.net/errors/500/
2
RewriteEngine On
3
I do not have an htaccess file here, do I need 1?
user name is epiz_32679036
when I add the following rewrite rule a 403 error appears only in my subfolder.
RewriteEngine On
accessing main/subfolder/file without html extension works correctly per above directive
but
accessing main/subfolder/ produces 403… there is an index.html present in the subfolder but access is forbidden
thanks in advance for your help
Please don’t create multiple topics on the same issue.
Thanks
Thanks guys very much for your help. After playing around a bit I solved my problem. It was as simple as just adding an htaccess to my subfolder. I am not sure why this worked but it did.
