old screen or 404 error
new page https://myrailmaps.free.nf/depot/index.html not showing - giving 404
I think your files may be going somewhere other than the folder your site is served from. I can’t tell from your post where you’re uploading, so can you tell me which of these applies?
myrailmaps.free.nf is on the one whose username ends in 440. If you’re logged in to the other one, the files would never show up on this site.depot/index.html inside the htdocs folder, or next to it?A similar topic had a 404 on a newly uploaded file, and the fix was to go into htdocs before uploading.
Here’s the topic:
It might be the same thing, but your answers will tell us whether it is.
Not the same issue
Have you tried to look on your FTP client if the file disappeared or shows the old page code ?
I can see the files uploaded on server - even opened them in edit mode on server to confirm they are the right versions.
Check spelling and cases
all are lowercase
Please screenshot your FileZilla window, at the place where you uploaded these files; not the online file manager.
I am using the online file manager - it is all I ever use
Online file manager recently showed some signs of handling the file names poorly causing unexpected 404s.
So you must use FileZilla to check if there’s something weong.
I honestly cannot spot anything wrong here, so I don’t understand why doesn’t it work either.
Do you have any .htaccess rules configured?
No - all I have done is updated the existing index.html - but it isn’t showing and added the folder depot and the index.html file within it.
I checked your website in the file manager and there is no depot folder in the htdocs folder of the account hosting myrailmaps.free.nf.
I also checked your other hosting account. The htdocs folder of that account does have a depot folder in it.
So it looks like you were just connected to the wrong FTP account, and were simply uploading the file to the wrong website.
Hi - Thanks - now resolved
