Images randomly not loding
Website: HIDDEN BY MOD
As the title says, images on my website randomly not loading. Every time i refresh, some images load, some does not. When I’m inspecting my code, the image is “impossible” to load but when I open it in an other tab, the image loads perfectly. Is it a known behaviour ? Thank you
Perfectly loading fine for me:
Strange, i tested it on 2 different computers accross several browser… I’ll try again later on some other computer then. Thanks a lot for your help ! :slight_smile:
Okay so it seems like it’s a network issue somehow, I tested it with 4g sharing and it works fine. No idea why tho.
I hid your URL because your site is vulnerable to hacking
Anyone can edit and delete directly
or manipulate the URL and get to the desired ID
e.g. app_form.php?edit=+(arbitrary ID)
2
in addition, I see here the possibility of file uploads
(I did not test if it passes and where they are stored)
so someone can upload a php file or a .htaccess file to take over your site
Yes thank you, i was just testing out to see if everything was working. I need to add the login system with permission etc. Thank you for being reactive
