Images not loading on Wordpress
I have this website : websitetest.epizy.com
Whenever I open it, images don’t show up. I have to open the image URL in other tab and then refresh the website to load it again. Any reasons why is that happening? I want to fix it. Please help me…
I have tried disabling all plugins, CHMODDING all the image files to 777.
Your website is redirecting to blusshbeauty.com but you are linking to images on websitetest.epizy.com. That’s not going to work, because of the hotlink protection system. You need to pick either the .com domain or the subdomain and make sure all the URLs use that domain name. Otherwise, the links will not work.
Thank you so much @Admin . If I had a thanks button, I would have pressed it a hundred times!! :#
