Images not appear
moodloungecaffe.wuaze.com
Some images do not appear
What image? What did you see and what did you expected to see?
http://moodloungecaffe.wuaze.com/Bebida.php
On this page, when clicking on “Cervejas” the images do not appear, is it because they are images with brands?
If I check the “Cervejas” page, I see a reference to an image Fino.jpg. But on your account is no file with the name Fino.jpg, there is only one called Fino.JPG.
Our servers, like almost all hosting servers from almost every hosting provider, run on Linux, and on Linux, files and directories are case sensitive. So Fino.jpg and Fino.JPG are not the same file.
For the best results, I recommend to only use lowercase letters in file and directory names, as well as avoid spaces and special characters.
