I'm having a problem with my Google Login
I’m having a problem with google-api autoloadreal.php. This is not a problem in localhost when I’m opening it in wamp
This is the code in autoloadreal.php line 78
What is this $file?
You need to check if it is missing…
The error message states that the file you are trying to open using
require $file; doesn’t exist.
If that isn’t the case than use absolute path to open the required file.
It looks like a file is missing from your site, specifically the one at careerpath/google-api/vendor/google/apiclient-services/autoload.php. Can you please check in your file manager if that file exists? And if it doesn’t, then can you reupload it from your computer?
Thank you! It is working fine now.
