I need help
Hi every one, i was using website building platform so i decided to move in here, the thing is that my website became unsecure and it get worse when i tried several times to extract a SSL certificate but it keeps telling me that it’s failed :frowning:
I deleted my domains from infinityfree but the problem still ongoing.
I want some help guys i don’t wanna lose my website :frowning: .
Are you trying to use ssl or leave infinityfree?
i want to install ssl but it’s not working at all
it keeps showing me this message every time
-----.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
I tried to install with sslforfree and many others but DNS records verification method doesn’t work at all !!
I think you are trying to do this wrong.
Use this link to add an SSL certificate in InfinityFree
Let me know if this helps!
Thank you greenreader, i tried it but the status still
No SSL certificate was found
should i wait for it or it should be instant?
don’t leave infinityfree. people here are very helpful!
see the step by step procedure, be patient
https://app.infinityfree.net/ssls
I won’t, I’ll wait till tomorrow to see DNS changes and hope it worke :frowning:
Here is the video that explains the process, he does a good job showing and explaining what you need to know.
Add SSL certificate in InfintyFree
It wooooooorks
so thankful greenreader i owe you :')
thank you all guys i’m so happy now :slight_smile:
