I need help with domain
https://mangatales.great-site.net/
If I buy a add-on domain will it transfer my files from my current site?
Thanks!
Hi and no, you have to do it manually (alternatively you can add your domain through parked domains so you won’t need to move files)
So your saying if I get a parked domain i won’t need to move my files?
You won’t need to move your files; you might just need to change the website URL on the thing you’re using to manage your website so it points to your new domain.
