I recently got a SSL from https://sslforfree.com after installing cloudflare, and I want to use the Full (strict) SSL option in cloudflare, I want to know how to install the certificate I got so I can use the SSL mode.
There are currently ongoing SSL errors. But you can install it in the Control panel under SSL/TLS
Thanks.
I installed my SSL certificate and it’s working perfectly, thanks for telling me how to install it, I guess i’m also lucky that i’m not getting any SSL errors.
