I have problem at database
epiz_26209350
MySQL Username epiz_26209350
MySQL Hostname sql103.epizy.com
Database Name epiz_26209350_0
how to use MariaDB in mysql database
if there is no solution tell me alternate solution
epiz_26209350
MariaDB is not available on our database servers. We only offer MySQL 5.6 database support, and if your software supports MariaDB, it will also support MySQL 5.6 as the database queries are the same.
thanks so much but i got some error can you figure out
from this code
CREATE TABLE config (
config_name varchar(255) NOT NULL,
config_value text NOT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
Well wait. Inno DB is not supported on free hosting services.
Okay then any alternative to inno DB
Well I’m not a expert here, so can’t help. Maybe others can help? @Ergastolator1 or @anon19508339
Only MYISAM is available here.
thanks then how to contact with them
okay thanks BayoDino i hope it works
can i use Atria or XtraDB
how to use chmod
MyISAM is the storage engine to use. We do not support any other persistent storage engines at this time.
In which context? What do you want to chmod and through which method?
