I can not enable cloudflare
Hi. I want to enable cloudflare for the webpage simter.epizy.com. But it evver tells me something that it can not do that and that i shoult check if this is the main domain, which it is. Can someone help me?
Issue is because Cloudflare doesn’t support sub domains only primary domains.
Your question is now solved! ?
As what @Friendifie-Inc stated,
Cloudflare only support for domains not subdomains.
You can Buy your own domain from NAMESILO OR GET FREE FROM FREENOM. You can also get .com free from one host.
Yes, @Friendifie-Inc already said that. You don’t need to say it again.
Oh ok, I just want to assure because some people might need more to be convinced my in personal opinion.
