I am not able to install plugins in my site
I am not able install plugin. it says bad request.
Installation failed: The package could not be installed. PCLZIP_ERR_BAD_FORMAT (-10) : Unable to find End of Central Dir Record signature> @nathji said:
It’s possible that the plugin exceeds the maximum file size. Please try installing it manually.
@nathji please use ftp file transfer program to upload plugin. Maximum file upload limit is 10MB so split plugin into parts. But mostly plugins are from 1 MB to 7MB that are commonly used. Which plugin are you trying to install??
