Https://smartstuff.ml/
My website URL is:
What I’m seeing is:
I’m using this software:
wordpress
Additional information:
https://smartstuff.ml/
website url is https://smartstuff.ml/
Can you please try to upload your screenshot again? Your account is working fine from here (showing the default new account page).
I corrected the code for the image
Thank you for fixing the image @Oxy.
It looks like the free hosting server doesn’t properly recognize the Let’s Encrypt certificates we offer you. Given how popular Let’s Encrypt is, iFastNet should really add support for this. I’ve contacted them to get this fixed.
I just did some additional digging, and while I can reproduce the SSL error (more or less) on a testing script, I don’t get the same error in WordPress. This is also on a HTTPS protected site using one of our free SSL certificates.
So I’m not sure why you see this error but I don’t.
while installing plugin show error that update fail but when i see plugin area it shows that plugin is install but plugin dont works
yoast seo plugin
tried to activate woocommerce plugin
Another method that i can suggest to you to install:
  1. Download Woocommerce here: https://downloads.wordpress.org/plugin/woocommerce.3.8.1.zip
  2. Extract it to your computer.
  3. Delete the previous woocommerce plugin.
  4. Upload woocommerce folder into wp-content/plugins via file manager or FTP Client like fileZilla
  5. Try to activate WooCommerce Plugin.
