Https problem plz see this
I connect my site to cloudflare via infinityfree cpanal after connecting one day ssl work properly but after that it seems to that my site not secure.plz take a look my site techbyside.com
I guess your site is insecure cause of outgoing requests to unsafe pages.
e.g. you’re loading css/js/image files with link like “http\://example.com/somefile”, use “https\://example.com/” or adjustable variation: “//example.com”.
Can’t say for sure, mobile
Also: your site doesn’t forcing users to use https protocol, enable “always use https” and “use https rewrites” in your encryption CF section
Your ssl is working fine at my end and I did not encounter any unsafe request, all request are served through https.
Also I see that you have forced ssl which is a good sign.
Thank you Mr junior its working now.the mix content of http and https make this problems
