HTTPS not working for subdomain bechatter.gt.tc – Port 443 closed
bechatter.gt.tc
Subject:
Body:
I’m experiencing an issue with HTTPS on my subdomain bechatter.gt.tc. The site loads fine over HTTP (http://bechatter.gt.tc/), but when I try to access it via HTTPS (https://bechatter.gt.tc/), the browser returns ERR_CONNECTION_RESET and the page cannot be loaded.
Here is what I have checked so far:
  1. SSL Certificate Status: In the control panel, it shows that SSL is automatically enabled for subdomains. There is no option to manually request a certificate, and the status appears to be active.
  2. Port 443 Test: I used an online port checking tool (e.g., YouGetSignal) and it reported that port 443 on bechatter.gt.tc is closed. This seems to be the main reason why HTTPS connections are being reset.
  3. .htaccess: I have not added any HTTPS redirection rules, so there should be no conflict from that side.
  4. DNS: The subdomain is using InfinityFree’s nameservers as required.
Could you please investigate why port 443 is closed for my account/server and restore HTTPS access for bechatter.gt.tc? If you need any additional information or screenshots, I’m happy to provide them.
Thank you for your assistance.
Best regards,
Sail_With_Dawn
好有礼貌兄弟
Additional Information:
I’d like to add that my subdomain bechatter.gt.tc currently resolves to IP 185.27.134.144. I tested port 443 directly on this IP using an online port checker, and it also shows as closed. This confirms the issue is likely at the server level rather than with my specific domain configuration.
this will usually fail beucase of the way the server is set up.
However, it does seem that there is a problem with port 443 may be closed on some IP addresses. I’m sure Admin see this when he’s online
Yes, there are some ongoing issues with a new security system that needs some fine tuning. The IP address your website is on is currently affected by this, a notice is up on our status page.
