Https://boloscaseiros.plataformaeadbrasil.tech/
Hi,
My pages: boloscaseiros.plataformaeadbrasil.tech and offersanddeals.shop
Hello,
The Elementor plugin had an update 5 days ago and since then I can’t install it.
I can’t install the Elementor plugin in wordpress.
When trying to install it says “update failed”.
error that appears
Installation failed: boloscaseiros.plataformaeadbrasil.tech | 502: Bad gateway Bad gateway Error code 502 Visit cloudflare.com for more information. 2023-08-07 13:36:03 UTC You Browser Working São Paulo Cloudflare Working boloscaseiros.plataformaeadbrasil.tech Host Error What happened? The web server reported a bad gateway error. What can I do? Please try again in a few minutes. Cloudflare Ray ID: 7f2fe5a04d8b01aa • Your IP: Click to reveal 2804:d55:4725:3300:84c9:5f80:f246:5be6 • Performance & security by Cloudflare (function(){function d(){var b=a.getElementById(“cf-footer-item-ip”),c=a.getElementById(“cf-footer-ip-reveal”);b&&" classList"in b&&(b.classList.remove(“hidden”),c.addEventListener(“click”,function(){c.classList.add(“hidden”);a.getElementById(“cf-footer-ip” ).classList.remove(“hidden”)}))}var a=document;document.addEventListener&&a.addEventListener(“DOMContentLoaded”,d)})();
Help me please.
Help yourself by reading this post
