https://www.sosyalpaylas.com.tr/install/?page=req
.htaccess gives a Not Installed error and I cannot continue with the installation.
It’s saying the file is not uploaded, it does not say .htaccess is not installed.
Just upload that file (To the /Script
folder), you can probably find it in the installer you downloaded, or on Github if the software is open source
EDIT: it looks like that software is not free. Make sure you have a valid license for it, because pirating software is both illegal and grounds for permanent suspension of all your free hosting accounts.
If you do have a license, please contact the developer for support, they know more about what they built then we will. And if you don’t have a license, remove the files from your site and stop pirating software.
Thanks I will delete the software from the site
