How to verify domain ownership using HTTPS or DNS verification?
I am creating an SSL certificate for my site on ZeroSSL. They are telling me to verify my domain ownership. But how to verify?
You need to use TXT records, but they aren’t supported on free hosting to set unless you use your own domain and custom nameservers. Also, you can’t install a SSL certificate on subdomains, and if you’re going to use our nameservers, I suggest generating a SSL certificate from the “SSL Certificates” section of the Client Area.
Did you see this knowledge base article? It specifically references zerossl.com.
https://infinityfree.net/support/cannot-use-or-have-problems-using-lets-encrypt-or-sslforfreecom/
