How to solve this problem?
problem
I can’t enter on script installer for this reason?
Is this a server issue or something else?
Please tell me how to fix it
Since you did not provide more info, perhaps you can do a manual install?
Welcome to the forum. Have you accessed your sites control panel before using the script installer?
Accessing the control panel is needed to activate FTP, the file manager and script installer properly.
Otherwise, I find the script installer bugs out sometimes, give it an hour and try again
Please try again later or use the control panel.
Did you try again later, or try to access the script installer through the control panel instead?
