How to fix your connection to this site is not sure
My site is not working not loading with https it shows
It is only working with http but it shows
your connection to this site is not secure
Untitled
http://pubgbattle.rf.gd/
please help me to fix > your connection to this site is not secure
Make sure you have a certificate installed.
App.infinityfree.net/ssls
That’s because you have to get an ssl cert, here’s more info:
And here’s a guide on how to get one for free:
Copy and paste the certificate and private keys into the SSL section of the control panel. Make sure you leave the CSR section blank. After you copy them in and click “upload key”, try loading your site over https.
Now my site is loading in https but it is not loading proper well format in https mode
please try https://pubgbattle.rf.gd/
it is loading proper well format in http mode: http://pubgbattle.rf.gd/
please try both link you will see difference in web format
To fix that issue, you need to follow steps 2 and 3 from the provided instructions:
Thank you very much after reading this article i found my mistake in script in Base URL i was using http then i changed it to https
$config['base_url'] = 'https://pubgbattle.rf.gd/';
now it is working.
