How to fix the www to https for all pages
https://www.mountainparadiseairnbn.is-best.net/
After switching to https because the SSL certificate did not work with my site after your upgrade. I change the site on the database, but now I get this message
how I change all url to https only or I need to do something else?
you’ll need to remove the www. for the ssl to work. I’m not sure how this works with the google search console though
How I remove the www. for all pages?
It depends on your site.
If it’s WordPress you can change it in your WordPress settings.
If it’s a static site you can use a .htaccess rule to remove
Better yet, edit it so instead of redirecting people from the non-www version to the www version of your domain, redirect people from the www version to the non-www version. That should be better for preserving search engine rankings.
That’s what I meant to do :slightly_smiling_face:
Thanks, I will do that and see how it goes.
