How to fix my database
My website URL is:
What I’m seeing is:
I’m using this software:
Additional information:
Can you please compile the template, as we need to know what will be your problem?
i’m tired to fix these
Error Number: 1146
Table ‘epiz_24759408_Sch.settings’ doesn’t exist
SELECT setting_variable, COALESCE(setting_value, setting_default_value) AS setting_value FROM settings WHERE setting_access_group = ‘public’
Filename: models/M_settings.php
Line Number: 70
It says table Settings doesn’t exist. Create it if you’re developing your own app or try to reinstall the software you’re using. It seems that database configuration wasn’t successful while installing.
