How to add SSL to Subdomain?
How do i add an SSL to a subdomain? I tried using the normal ssl stuff but in the cname section i have no option to select the subdomain i want to add it to
Is it an InfinityFree subdomain or your own sub-domain? Please tell us your domain name.
its my own subdomain: user.commission.ml
Request an SSL through the Client Area like this
i did do that but in the cname section there is no option for the subdomain
I think you must add it like this:
_acme-challenge.user
_acme-challenge.www.user
and use the domain commission.ml.
ok i will wait for the DNS status to update and will reply back if it works or not
thank you it worked
