How to add same SSL for sub-domain also.
I’ve an SSL for my main site, and I also want it to add same for my subdomain also,
How to do it.
Main website: https://learningwithexperts.ml
subdomain: forum.learningwithexperts.ml
How to do it.
Simple: just install another certificate for your subdomain through the SSL/TLS section.
Note that SSL certificates are only valid for specific domain names and don’t cover all subdomains by default, so you may need to get a second certificate.
Can’t I install same SSL labeling issued to learningwithexperts.ml,
Like your website: issued to: ssl378142.cloudflaressl.com
You should let Cloudflares cover your subdomain like InfinityFree.
U need a wildcard to cover all your subdomains and create ssl cert on Cloudflares and use this to cover all ur subdomains:
*.yourdomain.tld yourdomain.tld
THANKS!!!
Thanks everyone for all your Help!!!
But better way that InfinityFree should get in touch with “Let’s Encrypt” to get SSL comfortably.
We are already working on it! There are some technical considerations on our end which we need to address first before we can offer SSL for everyone, but it’s definitely our intention to do so.
@Admin, Great News!!!
But I want to report a bug here, that I’m not getting e-mail notifications, when you reply.
I’ve checkboxed all my notifications under E-Mail…
