how modernbb is installed
you’d download its source from:
then upload these into htdoces.
I also want to add and correct things on your guide. Aren’t you supposed after downloading the zip to extract it and only upload the files inside the folder with a FTP client on the htdocs, instead of uploading the zip file directly and extract it (it may take years to do that sometimes), then create a database, direct your browser to http://yourdomain.com/install.php
, follow the instructions and hope for the best?
I have one last doubt. Is this forum made in modernbb?
Looks like phpBB to me. Also seems they are using this free forum platform: https://www.forumotion.com/
