How do I provide https to a subdomain address?
Username (e.g. epiz_XXX)
my subdomain address: HIDDEN BY MOD
You can use CloudFlare:
In exactly the same way as you do a custom domain?
Do please note that the Record Name / Domain splittin in the client area isn’t correct. You need to select the base domain in the Domains list in the control panel and append your subdomain to the Record Name. So you would create CNAME records for _acme-challenge.forum and _acme-challenge.www.forum.
If this is the case, then I kindly ask to update the knowledge base article since it provides incorrect information about subdomains.
That section is about free subdomains, like example.epizy.com. It does not apply to subdomains of custom domains.
