How do I fix this issue?
Did you install SSL cert?
Is my SSL active?
Dun think so. Url?
Which one?
It’s my website url- www.movienest.xyz
Seem like a movie sharing site.
Did you read the TOS?
No, it’s A movie review site. And I read the TOS.
Your private key and SSL seem to be missing the last line statement.
Where do I put this code under .htaccess?
RewriteEngine On
After line 15
I have SSL Active. Do I have to put the above code?
If you are using CloudFlare, no.
Make sure * In the SSL/TLS → Edge Certificates tab, the setting “Always Use HTTPS” is set to On.
No, I Don’t use cloudflare.So, what I do now?
What’s that?
Screenshot says your website is using CloudFlare (unless I am mistaken)
Ah, actually I’m new. So I do not understand. I would have benefited if you could tell me what to do now.
I can only help you if correct info is provided
