How can i upgrade the max upload (on WP) from 1MB to 10MB?
Hello,
I would like to build my first website based on Wordpress.
But when I want to upload something it‘s limited with 1MB.
I have read that 10MB is the limit of the free hosting service. (or not?)
How kann I change this?
I haven‘t found a Solution in the Internet.
SunGhost
10 MB is the file size limit, but it’s possible that your WordPress is bugged if it can’t read 10 MBs. Try creating a phpinfo.php script on the htdocs folder with the following code: <?php phpinfo(); ?> and try to check with it if the upload_max_filesize variable is set to 10 MBs. If not you will have to reinstall WordPress or upload the files you want to upload with FTP.
