My account has repeatedly been suspended for entry-process failures. The graph shows approximately 280–290 daily failures on October 23 and October 27, above the displayed 200 limit. Daily CPU usage remains around 0–2%, and daily hits remain well below 50,000.
The site runs WordPress with only Elementor, SSL Insecure Content Fixer, and WP Super Cache active. WP Super Cache generates a fresh cached page, but its automated test receives 403 responses. Both the root and www DNS records are proxied through Cloudflare. Requests still receive the InfinityFree __test cookie and ?i=1 security redirect.
Is there an account/server issue, or are the requests responsible for the entry-process-failure spikes? What diagnostic information is available to distinguish traffic bursts, slow requests, and WordPress background activity?
It’s most likely the requests, not a server or account fault. I couldn’t find a source that says otherwise.
Our article on the limit says an entry process failure happens when your account is at its limit of simultaneous processes, so a new request is refused and the visitor sees an error page. It describes these failures as evidence of bursts of traffic that briefly overwhelm the account.
The article also says to compare entry process usage with hits. Your hits are low and your failures are high, so by that reading the bursts were short and intense, not sustained. Low CPU fits too, because the limit counts how many requests are in flight at once, not how heavy they are.
The article lists two ways to reduce the count:
Make sure static files don’t have a .php extension.
Cut down on AJAX and other background requests.
Every request to a URL on your site starts its own entry process, including ones that end in a 403 or the ?i=1 redirect.
I didn’t find anything on the forum or in the knowledge base about a per-request log or breakdown of what causes entry process failures. So I can’t point you to a tool that separates traffic bursts, slow requests and WordPress background activity.
To narrow it down, what times (and time zone) do the spikes on October 23 and 27 fall at? And does your site have anything that polls in the background, such as an Elementor widget or a live-refresh script? Both would show whether the bursts line up with one source.
