Hosting issues
Not too long ago I switched to cloudflare’s nameservers and updated Cname records to point to infinityfree, etc and everything was up and Website was working perfectly fine until recently I started getting this ‘error in establishing a database connection’ any time I load the site and I can no longer access Softaculous installer on my infinityfree account…
This is the domain… Discoverytv.com.ng
I need help here please…
I see this
Make sure you have a valid SSL and are using the correct SSL mode
I’m actually using SSL from infinityfree
Yes, but you still need to setup SSL on Cloudflare’s edge. If you don’t have a self-signed certificate, place your Cloudflare ssl mode to Full (Strict). Otherwise, just set it to Full.
