Host FTP is not true
Hi Hosting Support,
My website URL is: beautyboutique.rf.gd
What I’m seeing is:
FTP
I’m using this software: FileZilla Client
Additional information:
I opened the CMD and added the following code:
ping ftpupload.net
Ping request could not find host ftpupload.net. Please check the name and try again.
* For information: I tried to connect in more than one different device and over a different network and the result was the same.
Greetings,
For me ftp://ftpupload.net/ works fine (tested with an Italian IP). For you maybe the ISP is trying to block connections to it, so try to use a VPN to connect to it.
Thanks for your prompt reply,
I tried to use vpn, but the same result appears.
As I can see, you are using Psiphon 3 to connect to a VPN. Can you please go here to see the full IP address, but not post a screenshot of it, and try to go to ftp://ftpupload.net/ on your browser? Or if it doesn’t work, can you try to execute this command on a Command Prompt:
tracert ftpupload.net
and see what it says?
However, I used an Italian IP coming from a ISP (I have TIM’s fiber connection, limited at 30 Mbps because of the old modem), not from a VPN, to test the FTP server if it works, so you might expect some issues. I recommend as VPN services TunnelBear and ExpressVPN, even if ExpressVPN costs more than TunnelBear and offers almost the same, but with different and more locations.
Is same result appears.
  1. I visited the website for show my new ip, is changed:
    ftp3
  2. I tried visited ftp://ftpupload.net/ but not working.
  1. I tried using the following command:
I got this result:
ftp4
Try to use 185.27.134.11 as FTP server, or unblock all TCP and UDP ports on your firewall (if there is).
Great!
Now is works using IP: 185.27.134.11 (without VPN)
Thank you so much,
