https://mygrantfamily.great-site.net
My WebTrees application has stopped working because PHP reports that the server’s temporary folder cannot be accessed.
The server’s temporary folder cannot be accessed.
sys_get_temp_dir() = “/home/tmp/”
ini_get(“open_basedir”) = “/php_sessions:/home/uploads:/tmp:/var/www/errors:/home/vol14_3/infinityfree.com/if0_42169229/htdocs”
WebTrees previously worked correctly.
I have tested the PHP environment and get:
PHP version: 8.4.25
sys_get_temp_dir(): /home/tmp
upload_tmp_dir: /home/uploads
open_basedir: /php_sessions:/home/uploads:/tmp:/var/www/errors:/home/vol14_3/infinityfree.com/if0_42169229/htdocs
I also tested the directories:
/tmp
Exists: YES
Writable: NO
tempnam: FAILED
/home/tmp
Exists: NO
Writable: NO
tempnam: FAILED
Therefore PHP is reporting /home/tmp as its system temporary directory, but /home/tmp does not exist and is not included in open_basedir.
Could you please check the PHP temporary-directory configuration on my server/account and restore the appropriate temporary directory or correct sys_get_temp_dir() to point to a usable directory?
This is causing WebTrees to report:
“The server’s temporary folder cannot be accessed.”
The problem appears to be a server/PHP configuration issue rather than a WebTrees configuration issue.
