Validation error
The selected custom domain is already in use on unaux.com. Please remove the custom domain from your account at unaux.com before you can host it on InfinityFree.
Well, do that
So you are moving to IF from ProFreeHost? Login to the control panel from ProFreeHost, go to the domains tab and delete the domain.
No delete select domain
there is no delete option, just a pause
A screen shot perhaps of the error?
Are you sure you are looking in the control panel?
You can probably “pause” the account. But if the account is active, you can go into the control panel and remove the domains from there. If it’s currently paused, you need to unpause it first.
