Help
Username (e.g. epiz_XXX) simnetwork.ga
simnetwork.ga
404!
We couldn’t find that page.
Please check to make sure you’ve typed the URL correctly.
This webserver is CaSe SenSiTiVe so ensure capital letters in the URL match the files uploaded.
[Go Back](javascript:history.go(-1):wink: 404 tutorials and help
i need to create a .well-known file to verify my website on some services someone can help me?
Clear your Browser/DNS Cache, the site works fine for me.
the site works fine but the .well-known folder no
Maybe this:
i dont need an ssl certificate i need to verify my website for brave
It’s same method. Read again.
ill read
but why there is a “automated tools lock” can i disable this
Nope. The security system cannot be disabled, Instead, use the InfinityFree ACME SSL Tool (Doesn’t support *.rf.gd or *.epizy.com) or use cname verification
Sorry, Well, You can only use alternate verification methods, accessing via .well-known won’t work. And the security system (Which you can’t turn off) will block http verification
ok i cant verify
