Help with nameserver
lightbyte.gq
Validation error
The selected custom domain is already in use on lightbyte.gq. Please remove the custom domain from your account at lightbyte.gq before you can host it on InfinityFree.
I moved domain away from MOFH but its still showing the error
Try removing the nameservers and wait for that to propagate (3 days). Then, add them back and wait for DNS propagation (3 more days). Then try adding it back to your account.
i already waited 3 days i changed them like 6 days ago
@PlayKittensInc, please do not hijack other’s topics. Kindly create your own topic following the template provided.
It’s been a bit of time already. I waited more than 3 days and am still getting the error
Now it is time for you to add the nameservers: ns1.epizy.com and ns2.epizy.com.
Also, Freenom has been known to have DNS (specifically nameserver) issues, you may have to press the set button a few times if the nameservers are not propagating.
i did but all dns checkers say literally no nameservers are on there
I will reiterate for you:
But even more importantly:
but the thing is that usually it would atleast show previous nameservers
but now it shows nothing
What would do this? All DNS-checking software I know of takes the most up-to-date DNS “listings” available and returns them to the client. Freenom DNS management should have the last-entered nameservers automatically filled in the box, but as I said:
ok i have no choice but to take another domain
It’s working now. A major part of working with websites is patience. If you don’t have it, you are not going to end up well.
Apparently, you didn’t, or you wouldn’t get this error.
Please note that the domain needs to be removed from the hosting account. Changing the nameservers on your domain doesn’t remove the domain from the systems.
Please note the error message as well:
If you needed to change your nameservers, it would say so.
