Help with my website
SebUnknown
http://sebsweb.epizy.com/?i=1
I upload a folder containing everything for the site but when i go to my website it just shows directory listing and the folder i uploaded, then when i click the folder it brings me to the website. How do i make it so that it doesn’t show directory listing and brings me straight to the site?
Remove the files from the directory and upload it straight to the htdocs folder
I am having the same issue :frowning:
Drag the files inside the elements file to htdocs
Make sure you have index.html or index.php file, and you upload your files to htdocs folder
I had the same issue and i renamed the file and it was solved. Rename the file to index.html or index.php!!
Glad to hear :smiley:
