Help with linking my already existed domain (Namecheap) with Infinity Free plan
Hello, I have bought recently a domain in NameCheap for my Minecraft Server for the domain to work as IP and I have learn from Namecheap that the domain can be used and as a Minecraft IP and as a Website domain the problem which I am facing is how can I add the domain to the Infinity host I want to say that I am running a Xenforo Website.
Did you check this knowledge base article already? https://infinityfree.net/support/add-your-own-domain/
Can I set the domain without changing the Servernames because I am using this domain and as Minecraft IP if I am going to change it I am afraid that it won't work like a Minecraft Domain I want the same domain to work and as a website and as Minecraft domain.
No, but you can add the domain to InfinityFree first, and then you’re free to change your nameservers to any one you want, usually users uses Cloudflare, if the DNS records won’t save after changing nameservers from InfinityFree’s to others - https://infinityfree.net/support/find-your-ip/
But note that you should add domain with changing its nameservers, just having A/CNAME record to InfinityFree servers will redirect your domain to suspendeddomain.org.
@EliteHitNetwork
Wait, are you talking about Minecraft Server Hosting here or just your Minecraft Server Website Hosting?
If this is a game server, then it is not possible to host here, this is a free web hosting only and not a game server hosting and besides the free servers don’t have that much resources that can handle your game servers. Buy a VPS or a Server hosting that is dedicated to minecraft.
If this is a website hosting for your Minecraft server then yea it’s fine as long as your website isn’t using many resources.
@UnknownLolz certain DNS records makes able to use subdomain as ip:port pointer, or just use A record to point subdomain to real server IP and use subdomain:port to connect, being used commonly everywhere
@EliteHitNetwork
If this is a game server, then it is not possible to host here, this is a free web hosting only and not a game server hosting and besides the free servers don't have that much resources that can handle your game servers. Buy a VPS or a Server hosting that is dedicated to minecraft.
If this is a website hosting for your Minecraft server then yea it's fine as long as your website isn't using many resources.
I already have  Minecraft game hosting and I have made a forum for my server here using xenforo.
