Help with infinityfree 404 page
Website URL : cathat.free.nf
help
i test all ways but i couldn’t fix it
i spend a whole day on this site and now im tired and i give up
forum is my last chance
also i tast all solutions of Redirected to InfinityFree 404 error page
looks fine to me
landing page is working but if you try to go to other pages
like : درباره cat hat
(link of the middle button in header)
it wont work
Mind showing your file structures? (e.g. a screenshot in the file manager of htdocs)
i read a 404 error post from a 80 music guy
he said that he uses a sql database backup and it work for him
so i guess im going to build site again but more careful
I am 99% sure that’s not that issue with yours
i hope so
note that this happened after i add mx and spf records from zoho , i need it for contact form 7
and i remove some ssl part in htaccess (i add them last day but after i install Easy HTTPS (SSL) Redirection i dont need them (i add the plugin last day too and both work fine , i dont think thats the case))
Seems like a corrupted htaccess file to me.
And why are you using this FTP manager? You should use FileZilla client if you do not prefer MonstaFTP.
in fact i use filezilla but my screen is not big enough to take screenshot of all files in one photo :joy: so i use an online ftp manager for take screenshot
infinityfree htaccess:
htaccess.htaccess (534 Bytes)
wordpress htaccess :
htaccess(1).htaccess (1.2 KB)
Instead of uploading the file, copy/paste the code and put it in this tag:
Test
for wordpress
# BEGIN HTTPS Redirection Plugin
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{HTTP:X-Forwarded-Proto} !https
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
</IfModule>
# END HTTPS Redirection Plugin
# BEGIN WordPress
# دستورالعمل‌های (خطوط) بین "BEGIN WordPress" و "END WordPress"
# به طور پویا تولید شده‌اند، و فقط باید به وسیلهٔ صافی‌های وردرپرس ویرایش شوند.
# هر تغییری در دستورالعمل‌های بین این نشان‌گرها بازنویشی خواهند شد.
# END WordPress
# Wordfence WAF
<IfModule mod_php5.c>
php_value auto_prepend_file '/home/vol2_8/infinityfree.com/if0_35037318/htdocs/wordfence-waf.php'
</IfModule>
<IfModule mod_php7.c>
</IfModule>
<IfModule mod_php.c>
</IfModule>
<Files ".user.ini">
<IfModule mod_authz_core.c>
Require all denied
</IfModule>
<IfModule !mod_authz_core.c>
Order deny,allow
Deny from all
</IfModule>
</Files>
# END Wordfence WAF
Replace it with this:
# BEGIN WordPress
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
# END WordPress
it blown up site :joy:
i test with my plugin on and off
h23
May I ask how you are inplementing it?
sure
this is the htaccess after add your code
# BEGIN WordPress
RewriteEngine On
RewriteBase /
# END WordPress
# Wordfence WAF
</IfModule>
</IfModule>
</IfModule>
<Files ".user.ini">
Require all denied
</IfModule>
Order deny,allow
Deny from all
</IfModule>
</Files>
# END Wordfence WAF
You are missing the ]
Thank you very much . you save me!
im sorry , your code works perfectly! i had mistake with syntax
thankyou
you truly save one exhausting day of my life
