Help! I can't find /public_html in filezilla! What do I need to do!?
Title says all :neutral:
Use ‘htdocs’ instead.
htdocs doesnt work i uploaded html verification file for google but it wont work
that won’t work
@Maxarya said:
that won’t work
Use a different verification method.
There is no ‘public_html’ with infinity free.
I just checked your account but I don’t see any HTML verification file in your htdocs folder.
yeah i removed it because it didnt work
Uhm it actually WORKS!
I did the verification before, all you need to do is put the file inside the htdocs folder
Yes it worked now thanks :smiley: all for your help
No problem M8
