What software are you using?
Im using pressfly source code
I really don’t know what pressfly is, try contacting the infinityfree supoort team.
you can also watch a tutorial on youtube
How?
They have no tutorial they said i need to contact webhosting to enable it?
Then contact the infinityfree
Hello , Putenv Is Disabled by Default for security reason and Can’t be enabled.
I dont have email them
What i need to do sir
Unfortunately You can’t do anything with this Cause it’s Disabled System wide.
Please ask your hosting company to enable it.
Please ask your script developer to stop using it.
Underrated reply.
