[HELP] CLOUDFLARE ERROR : No user_key.
Hello there,
I’m having a problem activating cloudflare.
When I’m in “indexcp.php?option=cloudflare” I select the domain and I press the button “Alter Cloudflare”, The system tells me that the domain has cloudflare disabled, there I click on “Click to Enable”.
But when I click on enable, the system gives the following error: **CLOUDFLARE ERROR : No user_key.
I was looking for a bit about this problem, in some forums comment that this should be solved by the administrator of the cPanel, since the key of cloudflare has expired or was deleted.
I hope someone can help me with this, thank you very much in advance.
You’re not the first to ask that question. It’s answered here: https://infinityfree.net/support/domains/cloudflare-caveats
