Help! A piece of code is duplicating after uploading, even with FileZilla
### Website URL
I am new to coding, this is my first time uploading anything to a hosting site. I used FileZilla and everything seemed to upload correctly.
However, when I click on the URL to view my website, a piece of code is being duplicated. The green bubbles at the top and bottom of this site are not a piece of the original code, and when I go into the Infinityfree file manager, the code listed there is the same as the code in my original files.
How do I fix this?
It is working fine for me!
For some reason, I cannot upload an screenshot.
I see this, if you see something else then try clearing your browser cache and then refresh the page
Thanks for your help!
No problem :+1:
Just FYI
The browser cache can be a tricky thing and cause all sorts of issues when developing a website
One one thing that I have found to be a real nightmare is when the browser caches a .css file because then no matter how many times you try to clear the cache the .css file persists
If you ever find you have this issue then add a version number after your file name and when you make a change increase the number, this will force the browser to re-read the .css file and cache the new version
Example
<link rel='stylesheet' type='text/css' href='style.css?css=0001' />
