Hello! I'm having an problem to certificate my SSL
my Website URL is: thiagoerick.ct.ws
and when I try certificate show this error…
SSL certificate error: The provider encountered an error verifying the DNS settings of your domain name. Please double check your nameserver settings and try again later.
Error detail: The TXT record retrieved from _acme-challenge.thiagoerick.ct.ws. at the time the challenge was validated did not contain QPAfYL5AWPUSTz5lVSJ-31PPMsLPsyCF1aUw1l7Ae7M (the base64url-encoded SHA-256 digest of h5rp33CryWw3pEPTVKfwq4ISSGflIcdspfK8n9-yHogfvELglfKeLbwZVNp78Q3L.E6HbDmOkq6_oFFWvjHS0Hd--ZWFX3c1n_U6Xy99c1XU). See https://tools.ietf.org/html/rfc8555#section-8.4 for more information.
Someone can help me?
Occasionally, the SSL verification can fail due to inconsistent DNS results or timing issues. Usually, there is nothing with the configuration, it’s just bad luck. All you need to do then is retry the order with the same information, and then it usually just works.
