Have a * cname record and not able to delete it
Website saurabhsharma.dev
Username : epiz_27433069
I have .dev domain it will only work when I have ssl installed but for this I have applied for ssl on infinityfree and added cname records for it but there is * name record already there I have tried to delete it but it is showing error and my applied cname records are not reflecting can you please check.
Thank you
In advance.
Just ignore the * name record and add the CNAME record required for ur SSL cert
Records are not reflecting yet!
Ur dns is still propagating. Need to wait…
It seems fine.
The * record indeed can’t be deleted. It’s hidden from view now to avoid any confusion.
The records look OK now, but they don’t appear to be picked up by all providers yet. But that should fix itself if you have patience.
