hi, it’s been a while i want my image in the index of my website but sadly only the half appear
Hello, can you give us the link to your website?
What have you tried?
What doesn’t work?
Do the images give an error (during load - like a 404)?
http://animestreaming.epizy.com/test.html
heres an exemple look at the source code. i don’t do error with the name of images
Try clearing your cache.
That could be it.
Unfortunately that website is blocked for me…
So… it doesn’t load but there aren’t any errors?
No 404s?
Check devtools’ network tab and see the requests going through to be sure.
nop, don’t work. this could be with infinityfree ? the code work on my pc (local)
I just want to point out that going off the name of your website, streaming/video sharing sites are not allowed on this hosting.
i know this is just a test
The entire image seams to load so your browsers cache or your wifi speeds may be to blame if the entire image does not show up for you. You cannot stream/share videos with InfinityFree hosting (test or not) so that part of your site (video.html) may not work. Also you need to call your index file “index.html” and not “index3.html” if you want it to show up on the homepage.
Thanks!
what ? but it’s don’t work with me how you do ? i clean entire cache and my wifi speeds is good
Seeing as @Thewebuser22 can’t access your site, I’ll give you what I can see.
I can see the images perfectly fine, so it must be a cache issue. Make sure there are no errors with loading the images. If you still can’t get it to work like that, try accessing your site on a different browser or device.
I just loaded your page normally. Try using an incognito tab, or a cellular device on a cellular network.
oh, problem solved i clean the cach but just in the 2days before not all so it’s don’t work thanks, shame on me
Nope, you fine! If you liked a post here, please mark it as the solution for others browsing the forum!
Have a great rest of your day!
